Old Aug 29, 2015 | 04:01 PM
onehundred80
Default Re: E Brake Cover/Boot?
Originally Posted by HOT FIYA
Just got a reply back from them! I'll make some measurements asap and get back to them. Does anyone know if the rubber e-brakes surround is glued to the center console?
Hi Josh
We definitely would!
We can easily do that if you could help us with some dimensions. Firstly, we'd need to know if the stock rubber ebrake surround can be easily removed. Somebody told me it's glued into the center console, could you please double check that? If you take pictures while removing the center console you'll be half done with the install write-upby the way.B: RedlineGoods
Pictures of the underside of the console.
