onehundred80
Not to ask the obvious but how many hoses were on the old TB?
If you say two then you have your answer.
If you only have one on the TB that is a vacuum leak of the highest magnitude.
If I knew the answer to that question I wouldnt be asking how many should be attached
When removing I didnt see the hose connection closest to the engine block. I did connect it however as it would be mighty strange to have 2 pipes and 2 connectors with only one plugged in.
I'm wondering if the MAF sensor is faulty.
