Old Sep 6, 2015 | 08:33 AM
onehundred80
Default Re: leak through fan motor
Originally Posted by RED DOG
When you remove that cover under the windshield wipers you'll find a drain on each side of the car. Those drains are clogged with debris. Carefully clean them out and then test them by pouring water in them. The water should drain out quickly onto the floor.
There are actually three drains, you are forgetting the funnel shaped one in the middle in front of the passenger side windshield wiper pivot. It does not get plugged often because the drain holes in the cowl are so small.
If your cars drains get plugged it is worth the effort to remove the aft wheel well liners and clean the silt and smaller debris that is dumped there. I did the passenger side and there was a lot of small debris behind the windshield washer bottle, I have to do the other side.
The end drains just dump the water behind the fenders, the center drain dumps it in front of the firewall.
You can see the drains in this PDF.
