Re: Changing fuel injectors-instructions/suggestionns
I use the TTM 550 injectors with Needs Wings cork rubber gaskets. You must spray (only) one side of the manifold gaskets with 3M spray contact glue. Also spray only one side of the 4 cork rubber O-rings that comes with the gaskets. When the contact adhesive gets tacky,press the gaskets and 4 o-rings onto the manifolds. Squirrel Crusher
Reason: There's only Four O-rings and not Six as I had first typed
