Old Sep 7, 2015 | 10:40 AM
gronda's Avatar
gronda
Default Re: Huntings revs after TB work...suspect Y pipe connection?
I used the same sensor with same housing I checked the hoses the only thing I'm mind is that probably my o ring slipped or I messed up the maf sensor when I cleaned it with the crc cleaner. I will try to take it apart again and see if the o ring its ok
