Old Sep 8, 2015 | 07:50 PM
pioneer4x4's Avatar
pioneer4x4
Default Re: Can't Remove Radio from Dash
Originally Posted by smokey847
There seems to be some confusion as to my problem.
With the radio in the dash, I inserted a key in the righthand slot. The key activated the latch and is stuck in the hole as it should be. I inserted the other key into the left slot, but the key will only insert about halfway and will not "catch." Therefore, I have one key stuck in the right slot--I cannot release it because the radio has to be out to do this. And a left slot that will not accept a key. One side works--the other side does not.
I gotcha, I'm home, but stuck working on work stuff. When I get a sec, I'll check my radio. have you tried putting an up or down arch to the tool? You may have to make a release tool out of something superthin like a pop can for the other side, if you can't get the left one to work.
