Old Sep 11, 2015 | 09:51 PM
onehundred80
Default Re: crankshaft position sensor plug end
Originally Posted by bobbie
help i really could use some help here. i have an 05 crossfire that has had starting issues. the code says its a bad crankshaft position sensor, so i replaced the part and still have the same issues. upon further investigation i found that if you jiggle the wires going to the sensor the car dies. so now im trying to find a new wire connector as pictured here or someway to repair this part as its not available, or at least i cant find one. anyone have this connector for sale or some insight on how to repair? thanks in advance
The CPS and the plug should fit together with the minimum of play between the two, the fit coming from these parts and not the contacts.
The Bosch CPS is said to fit tighter as the contacts on it are thicker, if a after market part does not fit reasonably tight to the plug then the contacts are bearing a load they were not designed to take.
Check the fit of the CPS and the plug, maybe it is too loose.
I have disconnected mine once and they seemed to fit quite tightly, the locking tab should keep the contacts in the correct position.
Lightly clean the contacts before assembly anyway.
