pioneer4x4
Maybe the air pump is running when it shouldn't and that would cause a lean code, correct? You might have found a cause. Before you pulled the fuse, could you hear it running after initial warm-up?
Yeah, it should only run until the coolant temp gets up a little bit, then shut off.
