Old Sep 17, 2015 | 07:44 PM
oledoc2u
Default Re: new record for my crossfire
Originally Posted by amx1397
not sure what or how the "kit" will be but maybe as i said,, a ford 9" (Housing being made now) to BOLT into the crossfire as the mb diff. does now ,,,and a 1 piece drive shaft that is a bolt in and of course axles that would fit the crossfire
1 kit = 1 ford 9" diff with whatever gears you want.
-----1 tcu set up for the gears you choose .
---- 1 one piece drive shaft
-----2 axles
don't ask the cost,, we don't know once the first one is made we will know,
I have funded the r&d will keep you informed. jim
I have a good idea of the cost from the quotes I have had in the past. But what a set up if you have that much torque and HP..... You will stretch that stiff suspension to pull the front end...lol. I hope to be able to have machined the spacer needed and put together a rear end like you welded, wavetrac and all. Then I am done... What times we turn will be it... Done modding after this...but it is sure fun watching you push the limits....
