Old Sep 19, 2015 | 06:48 PM
amx1397
Default Re: SRT-6 TUNER TAMPA AREA Stlll LOOKING
Originally Posted by UNDER PSI
Still searching for a SRT-6 / AMG Tuner in Tampa area , Most places hear I'm Eurocharged and have pulleys and say they only install factory parts , I've tried DP Auto Tampa (OK, but car usually lays there until they gety chance to work on it ) All other places I've called say they only do scheduled maintenance , I Want (1) my Supercharger Fluid changed (2) maybe install a pulley kit that reroutes the belt to avoid slipping (3) Transmission fluid & filter changed (4) Install of Eibach Pro kit with Koni Yellows along with Front?Rear Caster -Camber kit along with the knowledge of a proper spec alignment after that install (5) Finally I have a rattling that starts when A/C is switched on only ---Dealer took car and Re-Installed my belt and said he thinks it is my Eurocharged pulleys and gave me car back --I really haven't used car since Any suggestions as I drive my car and am not a DIY mechanic - Yes I would be willing to go to Orlando area if really needed Thanks
You should PM chuk, he and his wife drive crossfires and both work at a dealer in Orlando and everything you are looking for chuk has done more than once to his and kim's car. jim
