Old Sep 20, 2015 | 04:18 PM
GraphiteGhost
Default Re: Aggressive wheel rumble at 65+
Originally Posted by cdcrone123
I've replaced all tires with new ones and changed the wheel bearing ( inner and outer) on the passenger side ( where I assume its coming from). I've got a list of things to tackle on this car since I've purchased it and this one seems to be getting the better of me. Does anybody have this problem or could direct me towards another possible problem area?
Joints seem to in relatively good shape and don't pop wheel I rotate the wheel from lock to lock...
Perhaps the steering stabilizer is shot??
HELP!
I would check the wheel balancing, and if you have spacers installed I would check they are hub centric. Also, might want to look at the wheel alignment. I also would look to see if there is any tire damage, like a bulge or bad dimple in a sidewall. Good luck!
