Old Sep 20, 2015 | 07:18 PM
cdcrone123's Avatar
cdcrone123
Default Re: Aggressive wheel rumble at 65+
Originally Posted by Speedy4x4
Can you jack 1 corner at a time and Shake the wheel around, to see if that wheel is tight or if there is play, side to side checks steering, up and down ball joints.
Is your car a manual or auto?
If it is a manual, do u you feel more shaking in the steering wheel or more if you hold onto the shifter?
If it is a manual and you feel alot of vibration in the shifter, it could be in the driveline, driveshaft bearing, flex disc etc.
Is it a manual however I don't feel it in the shifter as much. I lifted it up and when I go from side to side there's a bit of play, by play I mean more like it goes ( cluck cluck?) Up and down is as tight as can be and I can't move it at all nearly. I defiantly feel it more in the wheel towards 65+ it'll shake hard back and forth
