Thread: New problem
Old Sep 21, 2015 | 12:52 PM
Valk
Default Re: New problem
Originally Posted by Den656
My engine management light has come on and off recently. I had the car in the body shop for a small repair and they left the boot open and the battery was flat on collecting the car.
They jumped it and I went home. The following day I took the car out for a small drive and the car stalled and was difficult to start. The day after I used the car and after a short journey the car stalled again came to a halt and would not start again. The engine management light is on again. After leaving it for about an hour it eventually started again.
Anyone have this problem?
If the battery was dead it might be the source of the troubles you are having
Driving the car after a jump start does not fully restore the charge to the battery
If you can use a volt meter ...check the battery voltage after it has been parked overnight and not run
The battery voltage should be at least 12.5 volts
Anything less would be the first thing I would be concerned about and rectify
