onehundred80
From the Service Manual;
The brake fluid used in this vehicle must conform to DOT 4 specifications and SAE J1703 standards. No other type
of brake fluid is recommended or approved for usage in the vehicle brake system. Use only MoparT brake fluid or
an equivalent from a tightly sealed container.
Obviously you do not have to use the Mopar fluid though.
I used MOTUL RBF 600.
It is a good idea to use one which is a different color and then you can see when the new fluid comes out of the caliper.
Thanks a lot will do that would you recommend a engine flush before a service , can't wait to get it out on the road
