Old Sep 24, 2015 | 05:58 PM
onehundred80
Default Re: Ignition switch ?
Originally Posted by fastfred
Thank you yes I have tried re-setting battery and moving the steering wheel and the key will NOT turn even a little bit it's stuck in the off position ....
Jiggle the key. If that does not work then you may have to fix it on the spot. Not many tools needed.
Read this set of instructions to fix the problem. CLICK
Last edited by onehundred80; Sep 24, 2015 at 10:32 PM. Reason: modified to go directly to the fix PDF.
