rickpabon
Hi there,
I hope this will help.
How do you remove the decorative cover on a 2005 Crossfire engine?
Simply pull up on the engine cover it is held in by four clips i believe. The cover with pop off with little strength used to pull it out of the clips . Then slide it towards the windshield to remove the air intake hoses. BK
The manual (I believe) instructs you to pull the cover up from the rear (off the MAF tube) then take the front two off. I usually remove both air tubes before removing the cover, it makes the job easier (for me). Installation is the reverse, making sure the intake sets properly over the MAF tube before snapping down the cover. I use a slight dab of petroleum jelly on the rubber rings, helps in re-installation.
