Old Oct 1, 2015 | 03:31 AM
o55ie18's Avatar
o55ie18
Default Key Fob - Keeps Draining New Batteries Within 5 Days **Please Help**
Hi guys
Current dilemma!! I have 2 Key Fobs, both worked years ago fine..
The unlock button on one of the fobs has been playing up for the past month and then finally gave in and wouldn't unlock, so i went to use my spare fob instead. Batteries dead!
Replaced the batteries, all ok and working, however this only seems to be lasting 4 to 5 days before stops working again. Change batteries, all works, another 5 days, same scenario.
I have to keep buying batteries and carrying them with me just in case they drain when out and about lol
Any idea what could be causing this at all?
This was the same for the original key fob and the new 'blank' case i have transferred the guts to (My old fobs were battered, marked, just bad condition from previous owner)
2nd key.. (unlock button wasnt working)... ordered a new blank key fob casing (to transfer the guts) as when i took the fob apart, the rubber that makes contact for the unlock switch had worn and basically didn't reach the button to action then unlock.
So, guts in new case.... doesn't work (maybe i have damaged the circuit board when removing?)
Talk about gutted!!
Do you think the battery drain could be a bad connection, broken solder at all?
Many Thanks in advance
Jason
