Billy22Bob
Sweet2002 - I hope you are reading all the past threads and knowledge on the effect of higher boost levels and in particular the NW intake manis....thats where you get most increases in torque - across the board - the intake manis specifically add better bottom end response (I guess - possibly becasue they arent tapered like the OEM's)....but I'm not sure the NW manis will fit an SLK32 with possibly less room under the hood...(note: I damaged my stock air filter after a broken angine mount - so she's close already)....
Yep. Read so much it gets confusing after a while. I have not seen the intake manifolds give the power claimed yet. Rob said the tweaked intakes would give 25hp, maybe he was talking about the big ones, but I think the smaller stock tweaked and I have not seen anyone get 10whp from them. I am very happy with the torque my motor puts out now and it is just that little bit up above. I would be surprised if I was not running lean with just the 65mm SC pulley. I only added 6.6% more boost with the stacked pulleys. hopefully Jerry was right about my need for larger injectors.
