Old Oct 3, 2015 | 09:23 AM
Sweet2002's Avatar
Default Re: stacked pulleys & 550cc injectors
Originally Posted by Billy22Bob
Sweet2002 - I hope you are reading all the past threads and knowledge on the effect of higher boost levels and in particular the NW intake manis....thats where you get most increases in torque - across the board - the intake manis specifically add better bottom end response (I guess - possibly becasue they arent tapered like the OEM's)....but I'm not sure the NW manis will fit an SLK32 with possibly less room under the hood...(note: I damaged my stock air filter after a broken angine mount - so she's close already)....
My SC pulley has rubbed a hole in the pad on the underside of the hood. First the fuel issue and then exhaust work. Then...........
