Old Oct 6, 2015 | 10:22 PM
Billy22Bob's Avatar
Billy22Bob
Default Re: stacked pulleys & 550cc injectors
Originally Posted by Sweet2002
My SC pulley has rubbed a hole in the pad on the underside of the hood. First the fuel issue and then exhaust work. Then...........
You mean the hood lining?...
Is it hanging down?
If you'r not afraid of making "non stock" then some remove this hood lining to help with the heat issue.
I don thave a problem with the rubbing apart from my SL55 air boxes rubbing...I've removed them for now to limit the damage to them and the lining. I need to mount them better and as low as possible.
Also as I mentioned in a previous post - once you break a LHS engine mount - it'll wear a hole if you dont pick it up pronto. Take note NOW of the play in the stick shift and when your engine mount goes - you'll notice this become much larger.
With your mods - and frequent WOT - you will do an engine mount. Find some cheap spares now.
