Old Oct 11, 2015 | 07:59 AM
ala_xfire
Default Re: ignition switch turns but no start
Bob, the CPS will not cause these symptoms, it does not start generating signals UNTIL the flywheel is turning.
This is classic RCM, either the 3 solder points or a flaky engine relay.
Probably not the fuel relay, as it would momentarily start, then die if that was the bugger.
