Originally Posted by hpmotors
Gauges - at this time, one option is to use the AEM for engine control and the stock ecu for whatever it can't handle. BTW, the xfire really doesn't have any gauges, does it? Where is the oil pressure, oil temp, afr, egt, water temp with numbers, etc? One AEM serial gauge can handle 19 different parameters. hp
speedo, easy...
water temp, easy...
oil pressure/temp, easy...
fuel level, not so easy, the ohm range is not like anything aftermarket... i guess changing the fuel sender unit or measuring the ohm readout and making a control box for it will be in order...
afr + egt, haven't seen a production car to ever have those... those are tuning tools only (wouldn't expect a factory car to go out of tune and expect the customer to tune it).
Pistons - all cars today have aluminum pistons, most are cast. Haven't seen a car yet that would not handle at least 6 psi which should give about a 40 - 45% increase - say 305. We use JE for pistons when building a NA racing engine with high compression. Stick with stock pistons when going FI. Cast pistons in a Miata have been standing up to 18 psi without melting. Key is proper fueling/ignition under boost. I'm willing to bet the stock MB pistons and rods are good to go. hp
speaking of aluminum blocks, those yes all have aluminum pistons ? this is my first car with a aluminum block but my previous iron block cars had cast steel pistons ... how were the iron blocked first generation miatas ?
Don't think it will take that much time.
For us, the biggest issue is finding a proper donor vehicle at a reasonable cost.
Cheers,
hp
are we talking about finding a theft recovery or something so you don't hack apart a new car ?
either way, good luck, you're the first person to come across this place that has mentioned doing this that i do not fear for. :-P you have a shop and the time and experience to do it ...
