Old Oct 21, 2015 | 09:45 AM
onehundred80
Default Re: No Start - Need addition solutions
Originally Posted by BuffNSoFly
Does anyone know when you read the VIN # from the SKREEM module does it show the full VIN for the car or does it only show partially?
The tech mentioned on both NEW modules it only reads "1C3" the first 3 digits of my VIN #. Also with the new modules the car will no longer do the "3 crank and quit" sequence but, with my old module it does.
Tech says the PCM needs replacing. To me it sounds like the PCM isn't recognizing the SKREEM module because of the VIN?
Basically they cannot do anything more for the car without a new PCM. I tried looking around but, only find one for $2000 (MODULE. Powertrain Control made by Mopar. #05189967AB)
The VIN number is programmed into the SKREEM and is not visible. The numbers you can see show that it is the correct part, but it will not function as it s VIN number programmed in it does not match the chip in the fob, your fob chip matches the VIN in the original SKREEM module.
Remember the PCM you buy must be the same as the one on your car, one from another model will not do.
