onehundred80
The VIN number is programmed into the SKREEM and is not visible. The numbers you can see show that it is the correct part, but it will not function as it s VIN number programmed in it does not match the chip in the fob, your fob chip matches the VIN in the original SKREEM module.
Remember the PCM you buy must be the same as the one on your car, one from another model will not do.
Your saying the FOB needs reprogrammed to sync with the new SKREEM module when its replaced? Or a new key needs to be programmed with a new module?
