Old Oct 23, 2015 | 02:02 PM
xxx_fire's Avatar
xxx_fire
Default NOBODY HAS AN ANSWER TO MY ISSUE. Help!
So my car has been sitting for 5 months since the first mechanic I took it to couldn't figure out the problem. Two days ago I took it to a new mechanic, called him today, and he to is unsure. He says "it might be" an issue with the ignition which will cost be around 2k with parts and labor. Or it might be an alarm issue. He checked all my fuses, they came out fine,and said my starter safety switch is good. Here are my symptoms.
1. Car won't start ( not even crank)
2. No click sound, nothing when key is turned
3. Car does start when I push start it( it's Manuel)
4. I change out the license plates lights months before
My car died and accidentally touched metal with the screw driver which blew out the fuse. I placed a "more powerful" fuse which I think might of melted alarm wires, because after that my alarm would go off on its own. I had to unplug the siron. Drove the car like that for months no problem.
5. The key fob is a bit damaged. The prongs that come in contact with the fob batteries broke off, so I cannot unlock or lock my cars via the fob anymore.
I know it's a lot of info, but this forum is my best bet. Getting advice from people that have lived it(you can't beat that).
Thanks in advance 👍
