Old Oct 23, 2015 | 03:12 PM
xxx_fire's Avatar
xxx_fire
Thumbs down Re: NOBODY HAS AN ANSWER TO MY ISSUE. Help!
Sure sounds like the 3 solder points in the RCM.
Have you tried resoldering them, or replacing the RCM module ?
search "Mystery No Start"
Good point it has happened before, also and this is a bit unlikely, not having driven the car for a while is the pedal clutch being pushed down?
The mechanic checked the switch under the pedal, and yes I do pump the clutch once a week when I push start it.
