JEFASOLD
Is that $225 each? If so that's about 3 times what they should be.
Check out the link. It is for a set of 6! The adapters for the injector harness are $25. of that. They are $33. each plus $4. each for the adapters as these injectors have an EV-14 clip and we have an EV-1 I believe. I was shocked at the condition of the o-rings of the stock injectors but after 14 years I suppose that was to be expected. I would suggest changing the O-rings themselves in not the injectors also at that price.
I am repeating another post here but I am using a tune for 450cc injectors that was generated for race fuel(TORCO @ full strength) which added 1.5* of timing and 30whp according to Jerry at E/C. I adjust for the extra timing with a richer amount of fuel. It runs in the 11:1 range with 11.5-11.9:1 my target. I don't track the car and am planning to do the exhaust with a DYNO before and after. Hoping to gain 15whp+. I either have the parts or have them on order. I'll make the call to the shop with the DYNO when all parts are in hand.Then if Rob's headers show 15whp+ in independent testing I will likely go for those.
Mark
