Old Oct 26, 2015 | 08:20 AM
Sweet2002's Avatar
Default Re: Bosch 550cc injectors for our motors
Originally Posted by waldig
If the fuel pressure is controlled, you can flood our engines at even 22PSIG boost. Larger injectors dont address the problem in my opinion. WW
I tried to get away with the stock 450cc injectors but Jerry at E/C said he had already pushed the stock injectors past the duty cycle he likes and it was he who recommended I get larger injectors. Now I can run 20-22psi boost and not go lean but run AFR's in the mid 11:1 range but not going into the 12:1 range. I could NOT address the lean issue with the adjustable regulator alone. I could get the first 2 gears to run OK but then the rest ran pig rich.
I am confused by your statement that if the fuel pressure is controlled our engines can flood at 22PSI. Could you clarify that please? Given the state of the O-rings on my stock injectors I am glad I did the swap as they had hardened to where it is likely they had started to leak. Highly recommend everyone change the O-rings at least. With stock boost the 450cc injectors are fine, with a 62mm SC pulley the motor is likely borderline. AFR gauge is a must. I imagine my motor was running lean up top when I ran just the 65mm SC pulley. Mark
