4drturbo
dealership aka stealership.
Save picture to your computer or phone and download photobucket. Use the IMG tags in front and back of the URL address.
Never heard of the tensioner going bad, which is what is used to take the belt off. The idler pulleys and superchager bearing would be a good idea to replace. I just replaced those 3 things last week. Didn't mess with the tensioner. Unless you have a ton of miles on your ride.
I changed idler, guide pulley, and have 65mm sc pulley all done last 5 months, car only has 60,000 miles on it, I put new belt on cause after I installed dcai from needswing I was getting belt slip.
I can actually see the tensioner moving tiny bit when car running. When car in gear it's making noise. Thanks
