Old Oct 31, 2015 | 11:15 PM
KDW4Him's Avatar
KDW4Him
Default Re: Steering wheel shaking
Originally Posted by Shaynes848
I have a 07 xf limited and could really use some help. About 2 months ago I replaced the front brake shoes and since then the steering wheel has been shaking. I have replaced the front tires and had them balanced but nothing changed. The brakes feel good it doesn't shake anymore or less when you apply the brakes so I don't think it is the rotors. I was told when I had the tires replaced that the right front wheel bearing had a little play but was told it didn't need to be replaced yet. The shaking starts at about 65 mph but goes away for the most part at around 75 mph. Any help would be great.
The only new parts are brake pads? (shoes are on drum brakes)
If the rotors were also replaced and it started after they were replaced I would not investigate tires. Unless the shop knocked off some wheel weights. What rotors were used? Was the runout measured after they were installed on the car? Rotors can be out of balance or have a heavy side.
