Old Nov 1, 2015 | 01:22 PM
JEFASOLD's Avatar
JEFASOLD
Default Re: stacked pulleys & 550cc injectors
Originally Posted by rmcdaniel12
After applying the the equation- Crank÷SC×6200, ive determine that maybe you should of only took your SC pulley machined down to 73mm. Yes i know only 1mm (.039) difference but that 1mm is 648 rpms different. 178÷70×6200=15,765 if you only took the SC down to 73, your numbers would be 178÷73×6200= 15,117. The 73mm may be the route i end up going. A 181÷74×6200 is just above that at 15,184. I wish we could get into more custom crank pulley sizes. That would make fine tuning much better.
That's a good idea, if someone could come up with a pulley that had a spline that you could just slip a different size pulley onto it. Interchangeable sizes and just a few minutes to change. Maybe this would lead somewhere. I don't know if my machinist friend could or would want to give it a try but there could be pulleys from 74 (stock) all the way down to 62 or so.
