Old Nov 4, 2015 | 09:14 AM
grip grip's Avatar
grip grip
Default Re: Mandrus Rotec INSTALLED!! Early pics
Originally Posted by JHM2K
If anything, the ride improved. The suspension has less weight to manage over the bumps, so the oscillation occurs faster and is more easily controlled. Perhaps it was a placebo effect, but I recall the car feeling more nimble. I would highly recommend these to anyone thinking about them... the finish is very close to the OEM SRT-6 wheel, with the machined face and silver painted windows. If you can get them, get the 19x9.5 +25mm offset. I was in a rush and had to settle for +35mm offset, and always felt the rear needed spacers to make the car look more "stable".
Aside from that, zero complaints. You WILL need a good premium wheel brush that can snake between the spokes... the spacing between the spokes is too small to allow a hand to pass through. The $20 brush on Autogeek would be perfect.
Negative, ghost rider.
Most importantly, they were "Steve approved".
