Old Nov 5, 2015 | 02:51 PM
onehundred80
Default Re: Trunk won't open
Originally Posted by pioneer4x4
OK, I thought the drivers door would have been off by itself. And the fuel door is Teed in to the passenger door, correct? If so, that would be an alternate way to activate the fuel door, cut that tube, and you can actuate the lock, then splice it back together.
You can see the Tee for the hatch and the line going up to the fuel door. As the fuel door operates only when locking the car with the fob it requires a separate line.
The two door lines pass by the bulkhead in a thru hole with cables.
