Ed Mahoney
Was changing the brake light switch a hard job ? Is it hard to get to & find & change ? Mine just started doing this no brake lights & BAS light on ! Goes off when I restart car but as soon as I touch brake pedal back on !
Ed, to get to the brake light switch you have to remove the bottom section of the dash panel. The switch is located at the top of the brake pedal. You have to remove two, two pin, wiring harnesses. The switch has to be turned about 90 degrees before it will pull out. I broke mine and had to use pliers to remove the rest.
If you are having this issue I would check the fuse panel inside the driver side door first to make sure nothing is loose. My brake light switch was probably fine. My fuse is loose.
