I've had the Solisto.Pro unit for a while now, and it has worked just fine. Recently, however, I've been interested in going after an option with no wires, so I bought a small USB Bluetooth receiver to experiment. It works flawlessly with the Solisto unit! Just plug the device into the USB port, and then connect the 3.5mm to the Aux-In port on your Solisto. My audio is great quality and I've had zero interruptions. Below I've attached the device I bought:
Bluetooth USB Music Receiver Adapter 3 5mm Stereo Audio for iPhone4 4S 5 MP3 | eBay
If you would like to keep the option to play through a 3.5mm cable, just buy a splitter and split the port on the Solisto--just don't play two things at once--you could blow your speakers. Somebody may have discovered this trick already, but if not, here's all the info! Cheers!
