Old Nov 12, 2015 | 09:59 PM
unsc005's Avatar
unsc005
Default Re: Catalytic converters - right sizes?
I just purchased a 2005 Limited Coupe with 116K miles on it. The only issues that I could find with the car are that the driver's side headlight had condensation in it (fixed thanks to this forum), the hood strut won't hold up the hood, and that there is a check engine light on due to a previous owner removing all of the catalytic converters. I had a diagnostic test run prior to buying, which indicated O2 sensor reading errors validating to me that the check engine was only due to the catalytic converters being removed. I live in a state that does not require emissions testing so this is not a problem other than the check engine light is annoying to look at and the exhaust smell is pretty potent. I have found Direct Fit catalytic converters from CATCO part #s CT-4378 and CT-4379. Does anyone have any experience with these or any other recommendations?
