So next was to get some bits ordered,
lowering springs
wheel spacers
Hid kit
Various LED bulbs
So the springs and spacers turned up Wednesday so that evening I popped into work and whacked them on, loved fitting the springs on the crossfire there so simple and only took 25 mins to swap out all four corners using the correct spring tool made for the Merc's I also rolled my rear arches to allow me to use my 25mm hubcentric spacers.
Here's a few bad pics as it was dark:
Lowered without the spacers:
and with the spacers fitted:
Today the HID kit and LED bulbs turned up so popped them in as well as a few other little light modifications.
While I was messing about with bulbs I took the orange indicator bulbs out and gave them a dusting with silver spray to rid the orange look and they still work perfectly also did the rears.
Before :
after:
next was to fit the HID kit and LED side light bulbs and LED number plate bulbs (left changed Right still stock):
Ive also swapped out the fog light bulbs for LED's and then re wired them as DRL's so there on when the ignition is on:
