Old Nov 19, 2015 | 05:36 PM
  #46 (permalink)
csteve0355's Avatar
csteve0355
Default Re: Mandrus Rotec INSTALLED!! Early pics
The two companies that told me 24MM were pretty sure that anything longer was going to hit the brake cable, so I feel for sure that the 24mm is the one for sure. I'm going to guess that the center hub isn't as thick as the stock wheel as the shank for the OEM bolt is 40mm.
Originally Posted by ATX SRT-6
28 to 24mm is a reduction of 0.158", just a tick over 1/8 inch. I did put a OEM bolt and a 24mm though the Rotec and there was plenty of thread sticking out the back. If you really want to be sure
pull an OEM rim off and stick an OEM bolt into it and measure how much thread length is protruding.
Then do the same with the Rotec and new bolt. Let me know what you come up with. My OEM rims are still at DT because the wouldn't fit in the car.
