ReignMan
When I turn the headlights on, I have no taillights. Like I said, the lights and tail lights were working fine before I altered the RCM, and after restarting it, and after a few minutes, I'm guessing the taillights went out.
I'll check to make sure that my bulbs are correct, and will report back if anything changes. Thanks for the troubleshooting.
I suppose that you could have had the problem before the RCM work was done, the light switch could be causing trouble, it has before.
When did you walk around the car and inspect the lights, I am confused with the time line here, others may assume the correct sequence of events but what I understand may not be true. You say you walked around the car and all was fine but after the restart it had problems. I cannot quite convince myself you are talking in minutes or weeks.
