Old Nov 23, 2015 | 04:31 PM
Travish's Avatar
Travish
Default Re: Radio Upgrade Kenwood KMR-D588bt or D56bt ?
I use the same usb also and it works great, you can put a ton of music on that tiny stick.
You can set up the radio to answer on its own. You don't have to press the source button if you don't want. The amount of rings before it picks up is a setting too. The volume is plenty loud. It even works with my dumb phone.
If you set the color of the display to match the dash it will be hard to see in the sun coupe or not.
