Old Nov 23, 2015 | 11:07 PM
crossfireusa's Avatar
crossfireusa
Default Re: Transmission Vibration in low gears
Here's my current list of possible solutions, ranked in no particular order
1) TCM, $100, used
2) Valve body:
New sleeve kit, $66,
Sonnax 68942 05K Overlap Control Valve Sleeve Kit Fits 722 6 Mercedes Benz Trans | eBay
Master Overlap Valve Sleeve Kit - 68942-05K - Sonnax
Rebuilt valve body. $399
722.6 OEM Valve Body
3) Modify valve body , negligible cost, seems to be very successful Sprinter modification for RSN, Rumble strip noise, which I'd describe my transmission problem as
https://dieselrepairblog.wordpress.c...on-rsn-repair/
My friend that sold me the car said the problem started out very slowly and then got worse, so I suspect the valve body has leaks, that have continued to allow more and more fluid to bypass, also this seems to be a very well documented problem with the 722.6...
Please keep the forum posted if any of these repairs are tested
