Re: Possible SKREEM module.. cont. from another thread
Folks,
First time post. Working off this last thread entry on the fuse #9. I am now suffering the SKREEM fiasco. I was trying to locate a short in the vehicle (radio is behaving erratically and somehow battery is dead after 12 hours) and pulled fuses systematically in the main distribution fuse box to locate the culprit. After running through nearly the entire lot, had to run over to Home depot and replace my digital multi meter which for some reason began to behave erratically during the troubleshooting. Unfortortunately, I Suffered the SKREEM module symptoms and so never was able to replace the DMM. I noticed that the FOB stopped working and the two vehicle start/stop symptom was executed three times after a batt disconnect each time. So ran thru all these threads to find out that a simple fuse replacement should have fixed the problem. Not in my case, since I replaced all the fuses up to the point where the DMM stopped working. Upon confirmation that the SKREEM somehow malfunctioned, I worked along with a Smart fuse to indicate a hot connection on the remainder of the fusesin the box. I'll be working on this fiasco over the Thanksgiving holiday.
