Old Nov 25, 2015 | 09:11 PM
onehundred80
Default Re: Panic Button Keyless Door Lock
Originally Posted by unsc005
I bought a 2005 Limited Coupe. It's a nice car, but I have found a couple of items that don't work properly with the keyless remote. When I press the lock button the doors lock and the driver's side front and back turn signals flash three time. The passenger side front and back turn signals do not flash and the horn does not beep. In addition when I press the panic button the front and back driver and passenger turn signals flash for three minutes, but the horn does not sound. The horn does work when I press it and all of the turn signals work fine when I put the turn signal on. I have checked a number of fuses that have something to do with the horn or turn signals. I do not know if the two issues are related and am wondering if anyone else has had a similar problem or any ideas on what else I should check. Any thoughts are greatly appreciated.
The horn does not sound when you use the remote to open or lock the car.
The horn does not sound when you press the panic button. It is a siren that sounds when you press the panic button.
The lights should flash once when you lock the car with the remote.
I believe the security pump module in the trunk may be the cause of the lights not working on the passenger side when opening the car, it may have some damaged contacts on a plug.
