Old Nov 25, 2015 | 10:22 PM
onehundred80
Default Re: Panic Button Keyless Door Lock
Originally Posted by unsc005
Thanks for responding onehundred80. Can you tell me where in the trunk that I can access the security pump module to see if there are any contacts damaged? As for the siren any thoughts on why the siren is not sounding when all of the turn signal lights are flashing?
The siren has batteries inside it and they are shot so they do not work siren.
The pump is behind the passenger seat and underneath the mat. To get at it the rear and right side upper and lower panels have to be removed. If you can slip a slim item down the back of the foam you may be able to see if it gets wet if water is present.
