amx1397
I see you were running 11.8 what is the 60' and what air pressure r u running?
and what tires? jim
They're MT ET street radials. 255/50/16 on 16x7 rims. I usually run right around 16 psi and they hook great. Very consistent 1.7x second 6' times.
Running 17-18 psi helps prevent the tires from slipping on the rim, but puts me at risk of the tires slipping on the track slightly. At 16 psi with a 1400 rpm stall I can usually go straight to WOT on the launch with no wheelspin.
