Thread: Airbag and Horn
Old Dec 3, 2015 | 04:56 PM
onehundred80
Default Re: Airbag and Horn
Originally Posted by mariontr
I took 2004 xfire coupe in for inoperable horn and I'm being told that I have to get the airbag replaced because the airbag is bad. since the horn is connected to the airbag and will cost $1600 to replace.. True or False. the car has 60K miles.. No airbag lights are on also, just no horn prior to getting it fixed..
I would doubt that the air bag and horn are connected in any way, why would they be?
Probably a fuse in the horn circuit, I think you are being taken advantage of. The horn has one fuse under the hood which I assume is OK as the other items on the circuit are working you say.
There is also a fuse and a relay in the Relay Control Module under the hood and this is where I suspect the trouble lies.
Did it suddenly stop working? What is the story behind the problem.
