Re: Alt. Problems
Well that is a surprise, GM has not used a seperate regulator since the '70s Guess Merc is a bit behind the curve: REGULATOR. Alternator. Bosch. . ST 68053747AB.
Lights flickering is common if there is a bad connection to the battery or battery itself is bad as the regulator switches in an out.
In a good system the battery itself acts to stabilize the voltage.
