Re: Installed HIDs - concerned about wiring
Info about the high amp fuse taps near the battery.
I found out the fuse taps that can be used are AMI MIDI style fuses or Littlefuse BF1 32V fuses.
They are available on EBAY from 30 amps to 200amps for about $8 a pair shipped.
My Chrysler dealer was only able to order the 200 amp fuses ($6 each) and told me the smaller ones were no longer available for them to order.
The fuse holes are 30mm center to center (can use M6 or M8 bolts) and the fuse is 10 to 12 mm wide.
