tropixcale
UPDATE:
we have pulled out the rcm, it didn't look split but by all means had weak joints. My dad has since beefed them up. And upon reinstall my car has fired up fine. Cleared the codes reset the throttle and I pray that was it. Will update in 60 miles or if another problem arises. Again thank all of you so much♡
In an earlier post you said that you did not get a fault code and now you say you cleared the fault codes, which is correct?
If a code was set what was it?
