Old Jul 2, 2006 | 06:11 AM
woody's Avatar
woody
Default Re: Throttle Body Pics
Originally Posted by FirebaseD
please tell me about your port idea, I also feel if there were more then one TB on the intake the Crossfire would kick Azz without question, kinda like the 3 two barrel carbs back in the 60's and 70's... I've looked at the idea but cannot figure how i would mount another TB on the intake manifold... I do not feel splitting two TB to feed back into the same size mounting hole on the intake would get much done... tell me where your heading with this, I kept all your pictures you posted on this thread, thinks for the insight...hooah
Well the idea is to junk the single TB and 'trick' switched length intake plenum assembly (the big cast lump between the 'V', and replace it with 6 single individual downdraft throttle bodies (I looked at triple twins but the manifolding would be compromised). Like you say a modern version of a multi-barrel carb setup form the 60's.
Have a look here to see what I am working on.
Originally Posted by HDDP
Simon: when you had the TB removed, did you happen to identify a good location for a 7th injector that can be tapped into the housing ? I would hate to install an injector into the plastic pipe with the kind of abuse my car gets on the track.
There is not much room in that area so I am CADing up a 28mm injector sandwich plate to fit between the TB and plenum for those that want to retain the single TB. It will mean the MAF assembly will sit back 28mm causing problems with fitting the engine cover, but most people going this route will have ditched that anyway.
I am not sure which bits of the original MAF/elbow you still have with your ASK setup but it will probably just mean that the twin pipe assembly will move back 28mm nearer the firewall. I'll post up some pics here and on my site later.
